Αποστολέας Θέμα: KATANA'S  (Αναγνώστηκε 26092 φορές)
warover
Απ: KATANA'S
« Απάντηση #40 στις: Απρίλιος 16, 2009, 09:35:34 μμ »
Glossary of Japanese Sword Terms
Ashi   Small pattern of softer steel extending from the ji into the hamon. This pattern in the hamon was to prevent large sections of the cutting edge from being broken off.
Ayasugi   This is a large wavey hada
Bo'Hi   A wide groove or Hi in the blade. Often believed to channel blood from your slain opponent and commonly called a "Blood Groove." The Bo'Hi "groove" is to lighten the blade just as the fuller in a European sword.
Boshi   The rounded hardened edge on the point or Kissaki of the blade.
Choji   Clover or mushroom shaped hamon pattern.
Fuchi   Collar beside the tsuba
Gunome   Semi circular wave shaped hamon.
Ha   The cutting edge of the blade. Also the section that would be sharpened.
Habuchi   This is the transitional zone from hard to soft steel or the line defining the edge of the hamon.
Hada   The pattern or grain in the blade that is a result of folding the steel
Hamachi   The notch at the beginning of the cutting edge
Hamon   The line seen between the edge and spine of a blade where the metal is changes hardness. This is typical in Japanese styled blades from the process of differential tempering or hardening.
Hi   A groove in the blade. Often believed to channel blood from your slain opponent and commonly called a "Blood Groove." The Bo'Hi "groove" is to lighten the blade just as the fuller in a European sword.
Horimono   Carving or Engraving in the Blade
Inazuma   Streaks of hardened steel in a vertical zig-zag pattern in the transition zone habuchi. This type of hamon literally means "lightning bolts"
Itame   Wood-like grain in the steel, This type of Hada is similar to the side grain in a block of wood, with irregular rounded shapes.
Ito   silk or cotton hilt wrapping
Ji   The blade surface just above the hamon and below the shinogi
Jihadda   Grain pattern in the Ji
Kashira   Butt cap on the tsuka
Kinsuji   A type of hamon that means "golden lines"
Kissaki   The point or tip of the blade
Koiguchi   The fitting or mouth of the saya
Kurikata   Fitting on the saya for attaching the sageo
Menuki   The ornament under the Ito on the Tsuka
Mune   The back or spine of the blade
Obi   The Belt or Sash worn by the martial artist
Sageo   The cord used for tying the saya to the obi
Same   Rayskin used for covering the tsuka under the Ito
Shinogi   The ridge line defining the Yakiba or edge of the blade
Shinogi-Ji   The flat section just above the Shinogi
Tsuba   The guard on the sword.
Tsuka   The handle or the grip of the sword
Yakiba   The sharpened cutting edge of the blade
Απ: KATANA'S
« Απάντηση #41 στις: Απρίλιος 24, 2009, 10:07:43 μμ »
Το δικό μου που αγόρασα σήμερα έρχεται παρέα με το locker του που δεν επιτραπεί να το βγάλεις από την θήκη χωρίς κλειδί και φυσικά το δικό μου είναι κοφτερό και μάλιστα Α grade από άποψη δυνατότητας κοπής αλλά δεν έχω σκεφτεί καν να αρχίζω να παίζω με αυτό η να κάνω δοκιμές για το πόσο καλά κόβει απλά αν πάρεις κατανα είναι ιεροσυλία να την πάρεις ακονιστη
ΥΓ
Έχω κάνει ενδελεχείς μελέτες στο θέμα κατανα και δεν μπορούσα να αντισταθώ πλέον έπρεπε να πάρω ;D
φιλε νικο ηρθε?
περιμενω φωτο,
εντυπωσεις,
τιμη,
και το καταστημα!!!! ;)
γιωργος
warover
Απ: KATANA'S
« Απάντηση #42 στις: Απρίλιος 24, 2009, 10:10:00 μμ »
φιλε νικο ηρθε?
περιμενω φωτο,
εντυπωσεις,
τιμη,
γιωργος
οχι ακομα γιατι το μοντελο που ηθελα δεν ηταν σε στοκ και εκτος αυτου ζητησα και personal customization ;)
Απ: KATANA'S
« Απάντηση #43 στις: Απρίλιος 25, 2009, 08:10:48 πμ »
τι custom ζητησες παλι ? θα μας τρελανεις?  ;D
warover
Απ: KATANA'S
« Απάντηση #44 στις: Απρίλιος 25, 2009, 10:26:35 πμ »
Τα χαρακτηριστικά του είναι
Λεπίδα
Hand forged θα μου πεις όχι διπλωμένη και θα πω ναι μεν αλλά η διπλωμένη λεπίδα ακολουθεί την παράδοση αλλά με την σημερινή ποιότητα του ατσαλιού (high carbon steel 1095) δεν χρειάζεται να διπλωθεί (εχω παραγγείλει και 1 διπλωμένο με tri steel κατασκευή και θα το έχω σε κάνα χρόνο).(η Μέκκα των λεπίδων είναι οι tamahagane οι οποίες είναι από το παραδοσιακό ιαπωνικό ατσάλι και φυσικά είναι διπλωμένες)
Το έχτα που πρόσθεσα στην λεπίδα μου είναι το natural hamon με την μέθοδο clay temper το οποίο μάλιστα ζήτησα να έχει και διπλό κύμα  ή διπλή temper line πραγμα σπάνιο έτσι με την μέθοδο αυτή εχω μια λεπίδα με σκληρότητα 62 hrc εμπρός και 40 πίσω ,αρα εχω μπροστα δύναμη και πισω σκληρότητα για να μην σπάει.τελος
Το κέντρο βάρους είναι στις 5” αν και συνηθίζεται να είναι στις 7 με 8 αλλά αλλα έχω πολλούς λογους να το θελω στις 5(μεγαλύτερη δύναμη καλύτερη ισορροπία λόγο του βάρους τις κατασκευής )
Tsuka(λαβή )
Από μπαμπού  για να συνάδει με την ιστορία  menuki με τον praing  Mantis (μεταλλικά σύμβολα λαβής).τέλος η λαβή τυλίγεται με ιαπωνικό μαύρο μετάξι
Τsuba
1 απλο για αρχη δεν βρήκα κατι που να με ενθουσιάσει
Seya
Βαθύ κόκκινο γυαλισμένο για να τονίζει ότι πρόκειται για  όπλο
αυτα εν συντομια
Απ: KATANA'S
« Απάντηση #45 στις: Απρίλιος 25, 2009, 08:05:41 μμ »
εισαι kinky ......κατακοκκινη shaya....μου ερεσει αυτο ......ray skin δεν θα εχει ?
η tsuba μου αφηνει αποριες......
στειλε μου το λινκ σε παρακαλω ....να ονειρευτω λιγακι .....ελπιζω να εχεις βρει και τον προμηθευτη για τα tatami....
warover
Απ: KATANA'S
« Απάντηση #46 στις: Απρίλιος 25, 2009, 08:56:38 μμ »
εχει φυσικα ray skin αλλα ξεχασα να το γραψω
ΥΓ
δεν υπαρχει λινκ απο κατι που ειναι custom ;)
warover
Απ: KATANA'S
« Απάντηση #47 στις: Μάιος 13, 2009, 03:20:39 μμ »
Μόλις έφτασε
Απ: KATANA'S
« Απάντηση #48 στις: Μάιος 13, 2009, 03:52:18 μμ »
ok βαλε την dlsr σε τριποδο και βγαλε πολλεεεεεεες φωτογραφιες .......
ειναι μουρλια .....αυτη η κοκκινη shaya πρεπει να ειναι ολα τα λεφτα !!!
να δω hada kai hamachi να μου φυγει η καψα .....η tsuka ειναι new style prolonged και μου αρεσει!!!!!!
αντε βαλε τα tatami να μουλιασουν ......
καλοριζικο!!!!!
warover
Απ: KATANA'S
« Απάντηση #49 στις: Μάιος 13, 2009, 04:07:47 μμ »
καλοριζικο!!!!!
hamachi θα δεις hada οχι γιατι δεν ειναι foleded metal αλα απλο hand forged επιφθλασομαι ομως για tamahagane  ;)
ΥΓ
η dslr μου ειναι 140 χιλιομετρα μακρια (εχω Χανια αυτη Ηρακλειο ;D)
Απ: KATANA'S
« Απάντηση #50 στις: Μάιος 13, 2009, 04:11:17 μμ »
Τι με κάνεις βρε κοπέλι.  :D Σκέτος πειρασμός είσαι.
(Έχει να πέσει παντόφλα)
Καλώς το δέχθηκες και καλή προπόνηση.
Απ: KATANA'S
« Απάντηση #51 στις: Μάιος 13, 2009, 04:35:07 μμ »
πολυ ωραιο!
τιμη και απο που!
και ποιο καθαρες φιτο βρε Νικο ;)
Απ: KATANA'S
« Απάντηση #52 στις: Μάιος 13, 2009, 04:40:44 μμ »
Καλησπέρα Νίκο,
αν και δεν έχω κατάλληλη γνώση πρέπει να σου πω ότι φαίνεται εντυπωσιακό το νέο σου απόκτημα. Να το χαίρεσαι!
Νίκος
Αποσυνδεδεμένος takis63
Απ: KATANA'S
« Απάντηση #53 στις: Μάιος 13, 2009, 04:45:59 μμ »
Καλώς το δέχθηκες φίλε Νίκο.
Απ'ότι βλέπω πρόκειται για κομψοτέχνημα.
Μας χρωστάς τις λεπτομέρειες του εγχειρήματος (τιμή, απο πού κλπ) και βέβαια πιο καθαρές φωτό.
Να το χαίρεσαι!!!
Απ: KATANA'S
« Απάντηση #54 στις: Μάιος 13, 2009, 05:04:23 μμ »
<object codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0" type="application/x-shockwave-flash" data="http://www.youtube.com/v/S0GPlb8HivA" width="425px" height="350px"><param name="movie" value="http://www.youtube.com/v/S0GPlb8HivA" /><param name="wmode" value="transparent" /><param name="allowScriptAccess" value="never" /><param name="pluginspage" value="http://www.macromedia.com/go/getflashplayer"></object>
για να δειτε και το παγκοσμιο ρεκορ .....tameshigiri δεν ειναι αθλημα ειναι τεχνη.....
Αποσυνδεδεμένος zoltan
Απ: KATANA'S
« Απάντηση #55 στις: Ιανουάριος 15, 2010, 05:40:57 μμ »
Το χει ο τυπακος..
Απ: KATANA'S
« Απάντηση #56 στις: Φεβρουάριος 09, 2010, 09:07:39 μμ »
κυριοι γνωστες κανα καταστημα ευρωπαικο με αντικαταβολη να αγορασουμε σπαθακι???????????
γιωργος
Απ: KATANA'S
« Απάντηση #57 στις: Μάρτιος 28, 2010, 12:52:32 πμ »
λοιπον αγαπητε warover , τα βρισκω πολυ ενδιαφεροντα ολα αυτα.
Παντα γουσταρα τα σπαθια και καποια στιγμη πιτσιρικας ειχα παραγγειλει ενα παραδοσιακο κινεζικο απο την μανα μου που ειχε ταξιδεψει πεκινο και μου ειχε φερει ενα διακοσμητικο που παντα ντρεπομουν γι' αυτο!
Νομιζω λοιπον οτι ηρθε η ωρα να αποκτησω ενα αληθινο κατανα για να πατσισω τα χρονια ντροπης με το μουφα κινεζικο!
Επειδη δειχνεις να εχεις εντρυφησει στο θεμα θα' θελα αν σου ειναι ευκολο να με κατατοπισεις λιγο με κανα λινκ, προτασεις αγορας κλπ για να ασχοληθω λιγο χωρις να με πιασουν κοτσο.
Υ.Γ: προσπαθησα να σου στειλω πμ αλλα δεν τα καταφερα.
Απ: KATANA'S
« Απάντηση #58 στις: Μάρτιος 28, 2010, 01:10:53 πμ »
Ρίξε μια ματιά εδώ κώστα  http://www.coldsteel.com/
Εχει μερικά βιντεο για να πάρεις μια ιδέα
Απ: KATANA'S
« Απάντηση #59 στις: Μάρτιος 28, 2010, 01:15:51 πμ »
Πάντως έχε υποψη ότι είναι παράνομα, φονικά εργαλεία και όχι παιγνίδια ή διακοσμητικά για το σαλόνι.
